1850 build query |
Vulkan ![]() New Member ![]() Joined: 23 January 2011 Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 23 January 2011 at 9:04pm |
I'm currently in the process of biulding a couple of 1850 cabs. I realise the PD1850 is the best suited driver... but its a bit out of my budget. I've heard the Void V18 1000 driver works quite well in this desgin, am i correct in thinking this? Does anyone know of a distributer where i can get my hands on this driver?
Or can anyone recomend another driver that works well in this cab? (budget of about 200 pounds per driver) I'll get pics of the build up soon and im sure i'll have more questions as things move on... |
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2753 |
Void Acoustics LTD UK
Unit 10b Dawkins Road Ind Est Poole , Dorset, BH15 4JD United Kingdom Tel: +44 (0)844 410 1440 Fax:+44 (0)844 410 1439 e-mail: web@voidaudio.com |
Nice one, will give them a call
adyk ![]() Registered User ![]() Joined: 05 May 2009 Status: Offline Points: 442 |
http://www.bluearan.co.uk/index.php?id=VODV181000
This where ive got 4 from, hope this helps. Edited by adyk - 23 January 2011 at 10:05pm |
Bryan M ![]() Old Croc ![]() Joined: 17 July 2004 Location: England/Belgium Status: Offline Points: 2223 |
They are out of stock on v1000 i've been told, next delivery is in two weeks. Sounds like a lot of people asked for them for christmas....
yea, thats why i was asking, i saw that they have a load on order, but had no idea how long that would take. are there no other distibuters around?
also, when cutting the mitres for the wood, i'm having a bit of trouble working out how to cut the really sharp angles, as my saw only goes to 45 degrees... how did others get by this problem? any little tricks to share? |
chopper27 ![]() Registered User ![]() ![]() Joined: 17 January 2011 Location: highwycombe Status: Offline Points: 24 |
you can tap packers on the saw base |
yea , we ended up running one side of the saw base along a strip of wood and after one mistake it turned out pretty good. fairly happy woth how its all coming along atm
moyano ![]() Young Croc ![]() ![]() Joined: 12 May 2008 Location: Bedfordshire Status: Offline Points: 1219 |
second hand pd1850's !
