  New Posts New Posts RSS Feed - 1850 loaded with void
WILLIAM12345 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WILLIAM12345 Quote  Post ReplyReply Direct Link To This Post Topic: 1850 loaded with void
    Posted: 17 July 2012 at 12:41am
i soldered my speakons but someone said after a while they will over heat and fall apart. an that i should use spade clips . is this true?
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2012 at 9:08pm
No.
Every thing breaks eventualy (entropy etc.) but it won't be from it 'heating up'. As long as the wire you use is of a decent thickness it won't even get warm.
maxwell92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maxwell92 Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2012 at 6:33pm
Solder is probably more reliable, I can imagine spade clips vibrating off before soldering falls apart
ClackS02 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClackS02 Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2013 at 2:06pm
Not exactly on topic, but it relates:
When making 300+ amp connections in the car using 0 or 00 gauge wiring, it is suggested to crimp rather than solder (as solder never makes 100% connection) something about air bubbles....
anyway... for speaker wiring, soldering is ideal!! how do you think the speakons/jacks are mounted to the amp main circuit board?
Its quite a bit of heat to melt solder, so if its getting that hot... RUN AWAY :)
As long as your good at soldering, and there are no 'Dry Connections' you'll be fine mate :)
