  New Posts New Posts RSS Feed - 1850 - opened from the top
hdk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdk Quote  Post ReplyReply Direct Link To This Post Topic: 1850 - opened from the top
    Posted: 26 December 2009 at 10:13am
Hi,
I'm planning to build a pair of 1850's, and have a question - why not to make opened top (with screws) to have access to the loudspeaker, and omit rear door like in design plan ?
Anybody try it like this ? Maybe you have some suggestions ?
Thanks,
hdk
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2009 at 12:01pm
this might be problem at the front where the little panel sits across the corner.
also as the driver would be dropped in from the top the throat area would decreased and the chamber increased.
the battens you'd have to install would also do the same.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 December 2009 at 12:21pm
Sounds like a real redesign..
Might as well increase horn length from approx 5.5ft, to 6.5ft, to make it approx 45hz horn.
This page was generated in 0.092 seconds.
