1850 or 186 horns? |
wizard
Joined: 12 November 2004 Status: Offline Points: 10 |
Topic: 1850 or 186 horns?Posted: 21 February 2005 at 12:51pm |
which one should i make ...
i know the 1850's are gonna be better although i can only afford to make two.. i can afford four 186's coz of the driver price. if i was to bile for 186 horns later cpud i replace the drivers with the PD1850's withut problems or should i do it the other way round? also what amp do people reccommend for 4 1850's?
mans1000
Joined: 14 October 2004 Location: Slough Status: Offline Points: 1373 |
Posted: 21 February 2005 at 2:42pm |
Hi Wizard,if ur gonna replace the drivers later on,why not just save to make more 1850's.Bear in mind they are designed to be used in stacks of 4 for best results.Alternatively load them with Void 18-1000 as they don't need a sh*t load of power like the PD's.As for the amp,again go with the Void Infinite 8,or a high spec QSC. Hope that helps a little,I'm sure a few more guys on here will give u a few more pointers. |
