  New Posts New Posts RSS Feed - 1850 or 186 horns?
1850 or 186 horns?
wizard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wizard Quote  Post ReplyReply Direct Link To This Post Topic: 1850 or 186 horns?
    Posted: 21 February 2005 at 12:51pm
which one should i make ...
i know the 1850's are gonna be  better although i can only afford to make two..
i can afford four 186's coz of the driver price.
if i was to bile for 186 horns later cpud i replace the drivers with the PD1850's withut problems or should i do it the other way round?
also what amp do people reccommend for 4 1850's?
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2005 at 2:42pm
Hi Wizard,if ur gonna replace the drivers later on,why not just save to make more 1850's.Bear in mind they are designed to be used in stacks of 4 for best results.Alternatively load them with Void 18-1000 as they don't need a sh*t load of power like the PD's.As for the amp,again go with the Void Infinite 8,or a high spec QSC.
Hope that helps a little,I'm sure a few more guys on here will give u a few more pointers.
