1850 super scoops with 15" miniscoops as mids? |
Page 12> |
sliverr
Topic: 1850 super scoops with 15" miniscoops as mids?Posted: 17 April 2007 at 6:41pm |
error
Edited by sliverr - 05 January 2008 at 1:28pm |
moray james
Joined: 07 September 2005 Location: Canada Status: Offline Points: 141 |
Posted: 17 April 2007 at 9:47pm |
This link goes to the TDA site. There are 143 interesting cabinet design to look at and make coppies of. Each page has about 20 thumb-nails to view and if you scroll to the bottom of the page you will find the link to the following pages. Regards.
moray james
moray james
Posted: 17 April 2007 at 9:53pm |
Here also is the link to mid horn designs which I should have included above.
moray james
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 18 April 2007 at 6:02am |
This has been discussed here many times. Was agreed that HD15's (or similiar) above scoops is perfect complement to run from 70-180 or something like that. I personally think 2x15 reflex is next best bet, but not so hot outdoors. Selenium version of MT122 with right drivers, would go above that nicely. http://www.selenium.com.br/site2004/downloads/projetos/PAS5_p.pdf PAS5MA1 (Page 6). Would keep away from Beta12. Try Fane 12MB's, P.Audio 12's, or used RCF/ATC off ebay if cost is an issue. Edited by levyte357 - 18 April 2007 at 6:42am |
sliverr
Posted: 18 April 2007 at 11:21am |
error
Tom Umney
Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Posted: 18 April 2007 at 11:23am |
Piss easy to make yourself, just use WINISD.
levyte357
Posted: 18 April 2007 at 1:24pm |
Quite true, however even easier is buying a pair of used HD15's from For sale section in this site or squatjuice.com. If you can make decent 2x15 reflex, I'm sure you can make HD15's or even better, HD215's. Those would look proper sexy/professional over scoops, and sound the best inside or out. http://www.bl-online.org/users/lasse.lukkari/hd215/ ![]() http://www.bl-online.org/users/lasse.lukkari/hd215/HD215.pdf Unloaded pairs coming up all the time. |
sliverr
Posted: 18 April 2007 at 3:35pm |
error
levyte357
Posted: 18 April 2007 at 5:50pm |
The HD215's go above the scoops (approx 70-180hz), The Selenium Midtops go above that (12's = 180-2khz) 1.4" compression driver = 2khz -> approx 16khz. I was told you gotta use FANE/P-Audio/PD 12's to cover the above range, and that P.Audio BMD740/750 CD works good in this setup for cheap price. |
sliverr
Posted: 19 April 2007 at 6:50pm |
error
Tekasis
Posted: 22 April 2007 at 3:12pm |
ES-15BLH Micro-Scoop for Mids ??? or do you mean for upper bass ?
I previously thought of something similar, but used for bass.
See here:
Tom Umney
Posted: 22 April 2007 at 3:21pm |
Iration Steppas used to use dual 15 inch reflex for upper bass.
![]() A wild stab in the dark and found you some dual 15 inch reflex plans you should be able to make and find suitable drivers for.
I say Eminence Kappa Pro 15 LF makes a nice reflex driver. I got no experience of PD drivers in 15 inch reflex.
Page 12> |
