  New Posts New Posts RSS Feed - 1850 vs 186
1850 vs 186
Hi_Varu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hi_Varu Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 3:39pm
why not SuperBassHorn?or meatgrinder?
firefist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefist Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 4:38pm
??? never heard of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefist Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 4:47pm
hmm know thinking of making 8 of them superbasshorns instead of the 1850 what would people suggest
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 4:58pm
which "superbasshorns" do you mean?
if u play techno music a kicky punchy cab would be more pleasure than a deep bass growler...
goa, trance, house, minimal, etc. mostly have no deep bass, 50-80hz is what u expect to hear so a proper kick is a must! 1850s or even stacks of short horns like usb, hd215 or simmilar would do the trick easily and nicely. do u know any venue, dj, sound that uses real sub-cabs for that type of electronic music?
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefist Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 5:10pm
thank you so much thats all  i needded to here sorry for being so mixed up lol
ok here its is rig 1 will consist of-8 1850 for the momennt will have 16 in the future not sure mid/tops will get back to you all when i have finished the build
rig 2- 8-hd215's also will get back to you on mid/tops
venus - outside warhouses barns clubs teknivals e.t.c
Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 5:37pm
why do u want to build 2 different rigs?
i would build the 1850s first and see if i am happy with these or not, then decide whether to build more of them or not.
why one 1850rig and one hd215rig?
its much easier to combine both if they were all the same...
8x 1850s a side sound heavy and f..ing loud! -the more the better-
u will need some serious tops that can keep up with that bass-fundament.
theres not too many diy tops that can...
hope u bear these costs in mind when u build 16 1850s!
cheers
Dangerclaat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dangerclaat Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 6:07pm
Mate, go and have a listen to some different rigs, see what you like and dislike, and base (no pun intended) your choice on what you've found out. Simples
There'll be a time for dips daisy, but this isn't it
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefist Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 6:14pm
chheeeers for all your hellp it is much much appreciated http://www.youtube.com/watch?v=48UThQzIXDc&feature=related blame this lot for getting me hooked lol this is what we will be using the rig for next year will probally order the wood for the 1850's on friday then get to work building 8 for the mo @)
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefist Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 7:23pm
so 1850 will defo work for psytrance then before i order out ?? sorry for being so slow with all this
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hi_Varu Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 8:01pm
cheers
i mean this:
-we have 8 1850bins...we play moslty techno ecc..and we chose 1850horns cose we have no space to stack SupBasshorns in van.-Sbh have no phase problems like scoops cose are folded horns and will be "fast"enough.
-1850 bins is one bass cab , Sbh no, but with hd on top...
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2009 at 10:44pm
go listen some of them before you buy anything, because it's look like you don't know exactly what you're looking for... Wink
hd and 1850 cover about the same frequency, make one or the other not both...
if you really want two bass cabinet(sub+kick like hd15) then build some real sub like sbh, labhorn/12PI, wsx, X1...........but same here before you buy anything go and listen to them before.
INDECENT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INDECENT Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2009 at 7:59pm
we have a stack of 4 pd186 folded horns and a stack of V18 1000 folded horns and the 186s sound nicer on the lower frequencies, as matey said more musical... void 1850s and stasys 3 combination never fails to put a smile on my faceLOL
