  New Posts New Posts RSS Feed - 1850 which size driver
john_banny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john_banny Quote  Post ReplyReply Direct Link To This Post Topic: 1850 which size driver
    Posted: 01 June 2005 at 9:06pm
Hi sorry if this is the dumbest question u have ever seen but what size driver do u need for the 1850 cab. I will be working with the plans for the 1850s that are on this site. Is it 15" or 18" drivers i need. Also do u use 1 or 2 drivers per cab.
Thanks for any help and sorry again for the dumb ass questions.
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2005 at 5:13am
18",1 per cab.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2005 at 6:54am
In fact you need 1 driver specifically - the Precision Devices 1850 - hence the name of the cab.  Check out if you can afford them before you build the cab.  The 186 horn might be better if you plan on using an alternative driver as its a bit less extreme than the 1850
djbolo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djbolo Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2005 at 6:08am
Yesterday I made a project on Eminence Kappa 15LF which is very similar to 1850 and 186 but it can play from about 45Hz. If anyone is willing, just send PM to me.
Ps. sorry for my english, I'm still learning it.
