1850horn rear chamber size? |
Sencesync ![]() Registered User ![]() Joined: 17 April 2005 Location: United States Status: Offline Points: 180 |
![]() ![]() ![]() ![]() ![]() Posted: 20 August 2005 at 8:26pm |
anyone know how much volume the rear chamber is for the 1850horn?
rastaman ![]() Registered User ![]() Joined: 20 May 2005 Location: United States Status: Offline Points: 421 |
1 litre = 1,000,000 millimetres cubed
Rastaman, thats NOT what im looking for. im looking for the rear chamber volume size. not the convertion for millimeters to litres...
see this is why im trying to get the info from others. because i keep comming up with 69.74 litres no matter how many times i check it. and i HIGHLY doubt that thier is nearly 2.5cuf (70.8 litres) of rearchamber space in the 1850horn. so please tell me other-wise because i dont believe that there is that much room, it would seem like there should be less room.
Edited by Sencesync |
Ballpark it, it looks not bad to me.
Take the 3 largest measurements of the rear chamber as if it were a cube, you get about 87l, take the 3 smallest you get about 56l. Somewhere Rog talks about designing short horns as a sealed box unit first, which for the 1850 recommended enclosures are 90-220. Course I could be making the exact same mistakes as you, but oh well. |
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Subtract the volume occupied by the driver. Other than that, high
scool geometry will get you to the answer fairly quickly.
Yeah Rog says in the FAQ a standard 18" will occupy about 7litres if
memory serves. Seeing as he specs the 1850 for just about everything,
thats probably his standard
I'd expect that spec from PD, though to be truly exact one would have
to look at a little more detail (like thickness of the wood its being
mounted in)
tb_mike ![]() Old Croc ![]() Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
if you were one who must split inaudible hairs that is |
loophole ![]() Registered User ![]() Joined: 02 March 2004 Status: Offline Points: 469 |
not that inaudible mike.
an 18" hole in a double-thickness baffle (ie 36mm) is over 5 litres. certainly not incondsiderable i measure the rear chamber to be about 68 litres too. that seems about right, but im almost certain the pd1850 must be more than 7 litres... i would say about 15-20 is more along the right lines. and even that seems small compared to how much space it visibly takes up in the chamber |
minaximal ![]() Old Croc ![]() Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1780 |
i contacted mark from pd a while ago, and he said they work on a volume of approximately 6 litres of displacement from the 1850, i worked out the concave cone area to add up to around 3 litres to the throat area. looking back at my old spreadsheets: if the baffle hole for an 18" is 43cm dia, and 1.8cm deep, thats 2.6l on top of 3 litres, before counting the actual throat area. although dont forget the pistonic motion of a driver increases and decreases the area with each stoke... haha nothing is that simple |
