186 braces |
superspunk
Joined: 16 November 2012 Location: Spain Status: Offline Points: 65 |
Topic: 186 bracesPosted: 17 December 2012 at 11:54am |
Which is the distance between braces?
b grade
Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1333 |
Thanks(1)
Posted: 17 December 2012 at 4:50pm |
I assume you mean the dual braces in the mouth. I spaced mine so that they would be evenly spaced, and the internals all being 600 mm, I centered them at 200 mm apart and 200 from each side. So measuring from one side it would be 191 mm to 209 mm for the first brace and 391 mm to 409 mm for the second brace, taking into account that the wood is 18mm thick.
