  New Posts New Posts RSS Feed - 186 Hole cut Diameter?
_banksy_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Topic: 186 Hole cut Diameter?
    Posted: 18 January 2010 at 6:56pm
Hey,
 I have ordered my PD 186 For my 186 Horn I am Building, However I want to Cut the intalation hole for the speaker in my Ply before it arrives.
What is the Diameter or radius for the hole to be cut?
Cheers, Will
BreakBeat!
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2010 at 7:40pm
Well according to the PD data sheet (picture at bottom right hand corner) it's 414mm. But don't quote me on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2010 at 8:53pm
Thanks For pointing that out.
BreakBeat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 5:17pm
I will be cutting the hole this weekend. can anyone else verify this is the correct size. just making sure!!
BreakBeat!
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 9:26pm
I've checked an older data sheet (from when PD were in Cornwall), plus 3 other PD 18" that use the same chassis and all state 414mm hole for front mounting. But they could all be wrong.
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 9:55pm
Got blown ones here. I'll TRy and remember to measure tomorrow.
Tapeworm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tapeworm Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2010 at 2:35pm
When I built mine a couple of years back, I used the measurements off the manufacturers speck sheet and they were fine!
This page was generated in 0.143 seconds.
