186 Horn Crossover |
danparrott ![]() New Member ![]() Joined: 17 December 2017 Status: Offline Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 13 March 2018 at 6:01pm |
I'm building 2 186 horns with pd186 drivers, will upgrade to 4 in the future.
Thinking of powering them with a iNuke 6000 but just noticed the only crossover option is 100hz LP. Noticed on the 186 plan that it sounds good up to 200hz so was just wondering what people would recommend having the crossover set to and if 100hz will be high enough.
mini-mad ![]() Old Croc ![]() ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6841 |
200hz sounds a little high. Do you not have a cheap analog crossover you can sit with and have a play with the dial?
The internet telling you 200 is ok and PLAYING 200 are two different things... use your ears. If it starts to sound honky or stuffy that high up just back down on the dial til YOU like the sound! ![]() |
RemyK ![]() Registered User ![]() Joined: 02 May 2016 Status: Offline Points: 35 |
for me its 90Hz, for me on 120Hz it sound to "honky"
just listen to yourself, can differ per speaker I think Edited by RemyK - 03 February 2019 at 4:08pm |
