  New Posts New Posts RSS Feed - 186 horn or the 1850horn?
Sencesync View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sencesync Quote  Post ReplyReply Direct Link To This Post Topic: 186 horn or the 1850horn?
    Posted: 03 May 2005 at 1:18am
  whats better for B&C's 18NW100 woofer (T/S):
 THIELE-SMALL PARAMETERS
Resonant Frequency (fs)
34 Hz
Impedance (Re) 5.1 ohms
Electrical Factor(Qes) .29
Mechanical Q (Qms) 8.0
Total Q (Qts) .28
Compliance Equiv. Vol. (Vas) 227 Liters/7.9cu. ft.
Voice Coil Overhang (Xmax) 9.0mm
Reference Efficiency 3%
Diaphragm Mass (Mms) 201g
BL Factor 28 T-M
Coil Inductance (Le) 1.9mH
this is a 2,000watt woofer. just need to know, because the numbers are a little close, so witch would the woofer do better in?
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2005 at 6:12pm
Probably the 186. I would tend to model up individual drivers on the horn rather than just guess by BL etc.
How similar are the specs to the drivers designed for the horns is what I would look at.
