  New Posts New Posts RSS Feed - 186 or USB or ... ?
186 or USB or ... ?
alanstar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alanstar Quote  Post ReplyReply Direct Link To This Post Topic: 186 or USB or ... ?
    Posted: 17 September 2013 at 3:15pm
Hey all, I've got labhorns and I'm looking to build something to go between them and possible res3sh so I would want it do from around 60 to 200hz ... how does the 186 sound in the upper ranges ? On the description its stated as being very musical/hi fidelity, does this hold true for the upper frequencies ?
Thanks !
corell View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 3:55pm
No 186 for that range! To big and wont go that high. Also no need to go lower than ~90 Hz, if you got labs underneath.
Any 15" BPH should work fine. Try to simulate something in hornresp, search for limmer 115 or ask bee about his new cabs.
Meat View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 4:02pm
USB was designed for exactly this. The dimensions fit so it looks neat and it sounds good when properly set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alanstar Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 4:07pm
I prefer to cut the labs at around 60hz as they just seem to sound best there, otherwise you have to eq a lot of the upper sub freq out of them, so I'd really prefer to find a design that will go down to 60 or 70.
b grade View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 5:05pm
186 will certainly go down to 60, but like stated before, use of a 15 for kick would give a faster cleaner sound, and probably a more manageable size too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alanstar Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 5:08pm
Yes, I was originally thinking about using a 15 or a 12 as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 6:42pm
That was my thought aswell. I dont like the idea to use 18" for that range, if you are not after a one-bass solution and need it to go as low as possible (USB). Tell my a size and a budget (i guess its not that tight, as your after some f1 tops^^) and i´ll sim a 15" bph against a 12" or 2x12" bph.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 7:58pm
Labs 30-80 res 3 low from there id check settings
horn loaded for her pleasure
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 8:11pm
I tried a 15" BPH, 60 x 57 x 60 cm (i think labs are 57 cm wide?) with PD 158. Would be a really easy build, 106 db/w/m,  -3db points are 70 and 200 Hz when you use 4 of them. I will post plan and sim when i know how to do it.
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 8:19pm
Would be very impressive to see a new bph design, with those specs, made up in only 2,5 hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 1:24am
Uploaded with ImageShack.com
2 pi simulation is not that impressive, will try to improve it tomorrow.
And i am going to sim some other drivers in that.
The bracing in the backchamber is not necessary, i added it to decrease displacement, i would juse it for the door.
Edited by corell - 18 September 2013 at 1:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote alanstar Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 2:08am
Hi Mark, I'm planning on using the R3SH because I think I would rather have a separate 2x 15" horn than the 1x 18" horn in the R3.
A block of 8 labs sounds best cut at around 60hz imo.
