  New Posts New Posts RSS Feed - 18mm or 12mm ply?
18mm or 12mm ply?
dubsuction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Topic: 18mm or 12mm ply?
    Posted: 20 December 2005 at 12:57pm
hi, can anyone tell me if all the mt122 is constructed from 18mm (and not 12mm) ply? inc the horn flare part and baffles? would 12mm be unsuitable for this cabinet? i'm thinking of weight saving.
cheers!
phil
peace+respect-always
**HIGH PRESSURE SOUND SYSTEM**
www.highpressuresound.co.uk
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2005 at 1:54pm
I think it is easier to make this thing out of a mould, considdering that one needs a couple of these.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2005 at 10:45pm
Anything which is not a driver chamber or requires structural strength can most likely be made from thinner wood. 18mm can be excessive for some applications.
SteveSmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveSmith Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 4:58am
All the inside sections are 12mm and the sides are supposed to be 18mm. I THINK it would be okay, you could try it and put braces on the inside if they need it.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 8:13am
 what about these?
2 x 10''
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveSmith Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 9:27am
Fibreglass?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 10:57am
yes
144 pounds each
Edited by mykey - 21 December 2005 at 10:58am
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 12:34pm
Care to give details of where these marvelous mouldings can be obtained from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dubsuction Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 3:41pm
.... i just read the plan properly and its clear on there
a mould is an interesting idea, what would you use to mould?
anyone know of a more easily constructed cab to play in the 120Htz-600Htz range?
ta!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2005 at 11:26pm
they can be obtained from dansound!
his sight is still under construction should be ready in a couple of days he said.
danny 07914715221
Edited by mykey - 22 December 2005 at 6:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2005 at 11:27pm
www.janaudio.com
the sight isnt ready but pics are there
Edited by mykey - 23 December 2005 at 11:28pm
