  New Posts New Posts RSS Feed - 18sound 18LW2500
18sound 18LW2500
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Topic: 18sound 18LW2500
    Posted: 20 May 2019 at 6:47pm
Just got a used 18sound 18LW2500 to play a bit with.
Thinking about what to put it in.
Cant test it in the Gsubs, Only got one driver.
And dont think it will fit inside my EV MTL2 (and still missing one driver) or T18.
But wouldnt it be more fun to make something for it?
Maybe a mini scoop of some sort?
Ideas are welcome Smile
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:16pm
I was just about to buy some of these too! Was going to try some sort of double mini scoop! Are you keen to try building something? I was going to attempt them when i get back home in a couple of weeks
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:21pm
Using the 18LW2500 in a T18 or similar cab would be a waste. Build something with more extension, maybe a TH or something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:22pm
Cab dims are (mm) 1480h x 560w x 840d. Or can do singles as 740h. This is dual loaded in half space 2pi :) Looks like a good alternative driver to the 9601 or B&C 18sw115.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 7:44pm
Yes i will build something for it. Just for fun :)
I think mini scoop could be fun to try. Never build or heard a serious scoop. Only some oooold Fane 15" LOL
RCF ESW1018
Mykey Mini
MS18 mk2
Hugo Mini
HBL Mini
Bull X Mini.
Plenty of options :)
I know LOL
But thats what i got on hand atm. Also got some Fane 200L 18XB loaded cabs.
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2019 at 5:55pm
it have a thin weak cone try them in some paraflex cab that they sim well in.. but rip the cone apart in the 1st 15 min..
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2019 at 7:48pm
Eeeeeh 18LW2500 thin cone?
I would not call that a thin cone :O
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2019 at 7:56pm
A 290 g Mms isn't exactly a light 18", it's actually quite heavy. Xmax 15 mm, BL 30 TM, etc.
It does have a small Vas for an 18", medium Qes, so a front loaded horn with a small chamber tuned near 30 Hz would do (could be a ported horn).
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 3:50pm
let me see if i cant upload the video of me rip the cone easy with my hands
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 3:58pm
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:03pm
Originally posted by t.geessounds t.geessounds wrote:
https://www.youtube.com/watch?v=N_yKzBgdzh4&feature=youtu.be
Are you for real? LOL
Is that how you "measure" the strength of a cone?
Thats a first for me LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:26pm
Admittedly you make it seem easy. I could probably do that with most of my drivers though, except some of the cheaper but plastic cones.
