18sound 18LW2500 |
Page 123> |
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 755 |
![]() ![]() ![]() ![]() ![]() Posted: 20 May 2019 at 6:47pm |
Just got a used 18sound 18LW2500 to play a bit with.
Thinking about what to put it in. Cant test it in the Gsubs, Only got one driver. And dont think it will fit inside my EV MTL2 (and still missing one driver) or T18. But wouldnt it be more fun to make something for it? Maybe a mini scoop of some sort? Ideas are welcome ![]() |
smoore ![]() Young Croc ![]() ![]() Joined: 30 March 2011 Location: N.Devon Status: Offline Points: 933 |
I was just about to buy some of these too! Was going to try some sort of double mini scoop! Are you keen to try building something? I was going to attempt them when i get back home in a couple of weeks
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1039 |
Using the 18LW2500 in a T18 or similar cab would be a waste. Build something with more extension, maybe a TH or something.
Cab dims are (mm) 1480h x 560w x 840d. Or can do singles as 740h. This is dual loaded in half space 2pi :) Looks like a good alternative driver to the 9601 or B&C 18sw115.
Yes i will build something for it. Just for fun :) I think mini scoop could be fun to try. Never build or heard a serious scoop. Only some oooold Fane 15" ![]() RCF ESW1018 Mykey Mini MS18 mk2 Hugo Mini HBL Mini Bull X Mini. Plenty of options :)
I know ![]() But thats what i got on hand atm. Also got some Fane 200L 18XB loaded cabs. |
t.geessounds ![]() Young Croc ![]() ![]() Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
it have a thin weak cone try them in some paraflex cab that they sim well in.. but rip the cone apart in the 1st 15 min..
Eeeeeh 18LW2500 thin cone?
I would not call that a thin cone :O |
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
A 290 g Mms isn't exactly a light 18", it's actually quite heavy. Xmax 15 mm, BL 30 TM, etc. It does have a small Vas for an 18", medium Qes, so a front loaded horn with a small chamber tuned near 30 Hz would do (could be a ported horn).
let me see if i cant upload the video of me rip the cone easy with my hands
Are you for real? ![]() Is that how you "measure" the strength of a cone? Thats a first for me ![]() ![]() ![]() |
Admittedly you make it seem easy. I could probably do that with most of my drivers though, except some of the cheaper but plastic cones.
Page 123> |
