  New Posts New Posts RSS Feed - 18sound 18LW2500
18sound 18LW2500
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:28pm
lol well it rip up in the box in like 15min of testing.. have 4 boxes 2 the lw2500 an 2 with tbx100 .. up to now tbx100 is still fine...
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:33pm
Originally posted by mobiele eenheid mobiele eenheid wrote:
Admittedly you make it seem easy. I could probably do that with most of my drivers though, except some of the cheaper but plastic cones.
it was like ripping paper .. i had some old blow out lw2400 that i when home a try rip the cone the same way an no way it was so easy rip.. might be a silly test but .. anyway
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:46pm
What kind of boxes?
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2019 at 4:57pm
Thats some thick paper then :D
But lets get some facts on the table. Enclosure type? How much power? What type of material?
Many things can destroy a cone like that.
WessexAudioMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WessexAudioMan Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2019 at 7:10pm
Just out of intrest how do you rate the LW2500 over the LW2400 ? Different beast or is it just a slightly improved version of the lw2400 ?
Ive got a pile of Cubo 18's with the LW2400's in, have been very impressed with bang for buck and size
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2019 at 10:59pm
Its way more expencive then the 2400 for a start. It has much stiffer suspension and much stronger cone. Not sure how people have rip the cone up, but it is lot stronger then on the 2400. Almost 9601 strong.
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2019 at 11:43am
I've just ordered 4 LW2500 with the same thoughts after looking at the specs marjam! Seems like a good price for a driver similar to the 18sw115 or 9601
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2019 at 1:06pm
Similar yes, close to 9601 and SW115 performance, no. I have them all here.
LeruSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeruSound Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2019 at 4:24pm
Guys, 18Sound had some problem with old LW2500 lots, and that was, heavy driver with weak cone paper. I've been one of the first watcher of the LW2500 destroying on easy loads where whatever other speaker would have been survived.
So, i don't know if they solved the problems by the time, just write them an email and specify the lot number and tell dem about the problem. Guess they can give you some suppor..
Edit:
It was happening 3 years ago or some.. Watch out of the Qms, is 22!! You better watch out, of the tuning of the system, if Qms is that high you expect to destroy the speaker before the time.
Edited by LeruSound - 27 June 2019 at 4:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2019 at 5:52am
thanks u cause i know i wasn't crazy lol .
Jeevan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeevan Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2020 at 9:26pm
GOOD DRIVER
Edited by Jeevan - 15 June 2021 at 10:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeevan Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2020 at 9:28pm
rips easy
Edited by Jeevan - 15 June 2021 at 10:05pm
