18sound bandpass design |
Post Reply | Page <1234> |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Anyone got more experience with this cab? I would prefer the dual 21 but I'm limited to 580mm hight..
Main question would be; why build this cab instead of a dual 18 BR with equal drivers.
toastyghost
To answer your second question - because it's a shitload louder than a dual 18" reflex.
smitske96
Thats comforting
csijo
Registered User Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 102 |
Happy day friends of Speakers Plans
I am writing to consult you the following:
I have the possibility to buy 4 used bass 18 18LW1400 of eighteen sound, to be used in |
Audio Fanatics, Bass lover
ceharden
Will probably work fine. I like the 18LW1400 in reflex boxes and will be happy in a reasonable range of volumes. |
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
Being a reflex cab, how is it louder than reflex cab?
toastyghost
The thread title refers to the bandpass design? New page issues I guess, but the poster seemed to refer to that also |
smitske96
That was my thought also. How does it benifit from such loading under 80 Hz.
ceharden
If you look at the impedance plot for the cab on the 18Sound datasheet, there is some bandpass effect going on.
I don't think you get a huge gain from this kind of arrangement but it will increase the air loading on the drivers and you probably do get a small increase in efficiency or more likely just an improvement of the coupling of the driver to the air in front of the cab.
Pasi
It does, because 18sound themselves refer it to it as one. It doesn't have any real bandpass effects for it's intended operating range, and that little gain the slot gives is above 100hz, typically around 160Hz. Of course this reduces distortion on that area slightly and gives bit better loading for the drivers. Main reason why they refer it as a bandpass is that above 160 it eventually due to slot will give slightly faster roll off than normal reflex. They give settings for 10th order bandpass, and those settings confirm with normal reflex at the bottom end and bandpassy at top end. But only slightly. |
Pasi
It's not like i haven't done boxes in this principle in the past ;) |
toastyghost
Fair fair, but I’ve heard various builds of these designs (with and without ‘tweaks’) and they’re all super impressive. Perhaps simply because of that steeper upper rolloff, making them feel more like a sub and allowing them to be driven harder, but the end result is the same!
