18sound kit 18 sub |
Post Reply | Page <123 |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
Cabinet gain due to not having a very flat frequency response will boost frequencies above 50 Hz. Typically, when you are aiming for a really low response, your mid range cabinets must be able to cover all the upper bass (above 60 Hz) frequencies to make up the loss of the sub woofer. Also, observe the f3 listing in Bass Box Pro. If the driver is stating -3 dB @ 55 Hz as the box gets bigger, despite your fb is tuned lower, the loudspeaker cannot achieve anything below 55 Hz with great efficiency. Best Regards, |
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
True! Very interesting! Thought that reflex was easy peacey, but noo :-) |
LjudLahger
Had another go today and played mainstream tracks.
18sound cab are on its way out ;-) The upper boost give me no choice, have to cut them at 80hz or it will sound kicky in a bad way. A too slow kick that trying under stress and pain get the tones out. Fail... My new cab sound much better. Gives the trousers vibrations all the time and can be cut at 100-110hz. does not really matter what material. This is due to less muddy kick and lower response. With rock and pop a +3db at 90hz eq gives a nice punch without sounding too punchy or muddy. I'm really happy with my progress and next will be together with my mid/high cab. And later on in a bigger place because all the snow :-) Thanks for reading! |
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Hi.
which is your new cab?
LjudLahger
183L tuned 35hz with pd.186 :-) |
There is a thread that I made on the General Board. It offers many members posting youtube links to various tracks that offers a lot of emphasis below 30 Hz. It is a nice way to evaluate how low your subs can go. I rarely make threads so the topic should be the first one to pop up if you do a search under my name. Best Regards, |
LjudLahger
Thank's! Will look it up, pronto ;-) Maybe tomorrow or sunday the test will be of. Edited by LjudLahger - 08 March 2013 at 7:24pm |
LjudLahger
Test in a corner. I like the new bigger sub, to the left. A good day! Cheers! |
