19mm ply for Scoops |
Post Reply | Page 12> |
amarusia
New Member Joined: 18 August 2013 Status: Offline Points: 3 |
Posted: 15 October 2013 at 8:43pm |
Hey everyone! I'm going to use MDF ply to make 2 super scooper bins. The proble is that the plans have been made for 18mm ply, and here where i live, in Spain, I can use only 19mm MDF ply.
I have no idea about modyfing the plans for 19mm Could someone help me with modyfing the plans? http://www.speakerplans.com/index.php?id=18superscooper Thank you! :) Edited by amarusia - 15 October 2013 at 8:45pm |
RUS
one mm wont make any diffrence to the sound if it were me id just build to the plans.
whats mdf ply ?
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Spain isnt a third world country look harder and you will find 18mm birch ply.
amarusia
@RUS Medium Density Fiberboard.
I think that 1mm would make a huge difference on plans. @Sypa There is no problem with getting 18mm brich ply but we we have to use mdf ply because its cheaper. |
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
I'm with rus that little 1mm difference won't make a huge difference to sound and the plans wouldnt be too hard to adjust for 19mm I wouldn't say.
I personally would save for the 18mm birch in the long you'll be alot happier you saved. |
cassiya
Young Croc Joined: 13 January 2013 Location: london Status: Offline Points: 626 |
Never heard of MDF ply??? what is this? do you mean 18mm MDF with one faced with 1mm veneer?
Same stuff they use to make those fancy hifi speakers?
Just because you got more boxes that don't make you a man....
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
1mm will make no difference to the sound altho your gonna need to re work the plan to 19mm, would recommend just taking 1mm of all the internals to start with and go from there
This account is used by 2 people. |
TONY.A.S.S.
There are Manufacturers using ply in Spain, so it is available. When you eventually drop the cab, which you will, you will be glad you used Ply.
cassiya
Are you in the habit of dropping your cabs Tony? Next time you decide to drop a few, can you drop them outside my front door?
PinHole
Registered User Joined: 14 September 2013 Location: behind you Status: Offline Points: 93 |
If you really want to save money and nerves build them out of proper plywood. For fixed installation may be OK but on road NO. Learned it harder way - from personal experience. MDF is really not worth building effort if cabinet will be moved around frequently.
Artical Kulcha
Registered User Joined: 02 October 2013 Status: Offline Points: 192 |
Had/Seen plenty of MDF cabs use on fesitvals,carnival's inside/outside soundsystems, been fine and on the road for donkeys years, its how you look after them...
PinHole
Yes, can be used of course, but one mistake or drop from even little as single stair ~20cm as effect will give completely smeared corner turned into cardboard or in other case nice deep crack through middle of MDF panel .
