  New Posts New Posts RSS Feed - 1st gig of the decade..
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Topic: 1st gig of the decade..
    Posted: 05 December 2020 at 6:34pm
Some pictures from the Southbank
It has been some time since we had the opportunity to play with light. Here we are working under the direction of Light Artist Martin Richman installing his piece "Reflect" commissioned by Royal Festival Hall London for the "2020 Winter Lights" program running daily 3:00pm till 11:20pm from now until March 2021
All equipment supplied by Coloursound Experiment
Install by 4DPA t/as IlumN8
Edited by 4D - 05 December 2020 at 6:37pm
Bams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2020 at 8:52am
Let me be the first to compliment you on purely the fact of running a gig in these times :) is it an active piece or purelly the lighting itself? and why running it so early?
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2020 at 11:04am
it was dynamic using white light reflected from a sheet of dichroic foil at the bottom of a tray full of water with a solar fountain agitating the water, we also had clusters of source4 fixtures reflecting off sheets of foil hung from T stands agitated by electric fans which made a wicked northern lights effect. Scheduling was via MQ40
This page was generated in 0.031 seconds.
