2 speaker loaded punisher in one punisher |
pietjepuk
Registered User Joined: 19 December 2008 Status: Offline Points: 18 |
Posted: 12 January 2009 at 4:56pm |
what about this
2 speaker loaded punisher in one punisher firering both in one chamber or fire in one chamber
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
That's a completely new horn, but I'm not suggesting that it wouldn't work with a bit more designing. The Labsub uses a similar config with two drivers firing into each other. But it's not a punisher in any way shape or form.
Away on extended leave.
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
you got some odd things going on there - it would need some more cad work to get a smoother flare rate!
Edited by tomschute - 12 January 2009 at 10:10pm |
www.stableaudio.co.uk Speaker Building Services |
pfly
CAD? It looks MS Paint to me |
pietjepuk
i am working on it |
kiriiz
Registered User Joined: 09 January 2009 Status: Offline Points: 70 |
It may be interesting. Sure it will be great pressure on 2x Ciare 12.00 SW Need to be built!
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Can this double speaker setup be made to work ? Sure can, it's been done many times before.
Will it work just by fabbing up an extra speaker in almost the same cabinet or at least the same horn dimensions as the original Punisher? Nop !! Basically you must start from scratch and design an entirely new horn. |
