2 x Turbosound LS1802 |
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7302 |
![]() ![]() ![]() ![]() ![]() Posted: 16 December 2013 at 12:00am |
not high priority. just picked up a pair of TSE218.. one loaded, one is unloaded. have been reading tse 218 / 118 threads, and it seems nothing works like the originals.
just putting out feelers to see if there's a pair of these about. they would need to get to dublin. cheers. |
B.P.Sound ![]() Old Croc ![]() ![]() Joined: 28 December 2007 Location: London M25/M3 Status: Offline Points: 2662 |
I'm sure they are Fane 18B ? ? ?
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
Djdarch ![]() Old Croc ![]() ![]() Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1985 |
Not the 1802 thats a PD driver something like the PD182
older tse had a fane driver, ls1801.. these are a pd, with a 3" coil.
James Tengo ![]() Old Croc ![]() Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2132 |
i swear i've been searching ebay for turbosound.. how did they not come up?
cheers though.. presume actual turbo kits can't be had, but someone like roy would be able to deal with them... hmm... can't imagine a need for 8... hmm... |
have come across one..
still have eyes open for one ls-1802.. and now one ls-1804. |
TONY.A.S.S. ![]() Old Croc ![]() Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6878 |
Rare, having owned tms 4's and tse118's with both ls1801's and ls1802's and trying a variety of other drivers nothing compared to the 1802's
yep. i have 3 now... thought i had a pair in another bin i picked up but again there was one 1804 and one 1802. single 1802 isn't much use in a tse218 though.
i'm sure there's one (or i'd settle for a pd182) out there somewhere.. |
Robbo ![]() Old Croc ![]() Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4148 |
I have some of the Fane LS1801 drivers if they are any use.
Hepikuro ![]() New Member ![]() Joined: 17 January 2022 Status: Offline Points: 2 |
Hi! Im searching 8 original driver Ls1802 or similar for 4 tse218. Can u help me? I want to use them in the future for kick up to some 21''. Its correct?
Now i have 4 tse218 with Das 18-P with xover cut in 140 hz . My tops are two tfl760h with original drivers and i star in mid low with 180 hz. My question is that, use a kick section with single 15 or using tse218 as kick and try to build some 21'' paraflex to sub? The mosf impornt for me, now, is the Ls1802 or something like that. Thank u
