21" FLH |
Page 12> |
Ibex ![]() Young Croc ![]() Joined: 27 May 2009 Status: Offline Points: 1013 |
![]() ![]() ![]() ![]() ![]() Posted: 15 October 2009 at 5:54pm |
Hello everbody!
Does someone know something more about the following 21" FLH designs? Any audible impressions? Some facts about the driver, flare rate, folding, hornpath length? Would be nice to get some replies of what you think about these 21" designs! ![]() ![]() ![]() Do you know some other 21" FLH? Are there any 21" DIY projects out there? Here they are: - ASS SB 121H ![]() - Föön E545HL: ![]() - Porkolab BH 121: ![]() greez Edited by Ibex - 17 October 2009 at 10:11am |
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3130 |
i know its take 4 people to lift the ASS 21" and it has a pd2150 in
TRENDSETTER SOUND SYSTEM
I do believe, for my Audio-Guru 2x12" bassorns it takes 4 people too...
How do they sound compared to the well known 18" designs? |
What's the correct depth of the cab, because I also found these specs:
![]() D = 881mm or 1120mm ![]() Are there another disparities between the two differently sized cabs? Or was it just a misprint? |
DjMidKnight ![]() Registered User ![]() Joined: 31 August 2009 Location: Abq NM Status: Offline Points: 298 |
im not sure i know that vega has a 21" out now also that they claim can do 144db all by itself
Yes, you are right!
Now I can remember that I already saw the new Cerwin-Vega! TS-42 on the Pro Light & Sound fair this year in Frankfurt... ![]() Bummer, that I had no chace to hear it at full power, only silent mode, but it seemed to play forsooth as deep as what the specs assure, but I'm not sure enough. http://forum.speakerplans.com/new-cerwin-vega-horn_topic23859&OB=ASC_page1.html Edited by Ibex - 16 October 2009 at 4:39pm |
What are the advantages/disadvantages of loading a horn with a 21"?
Is there only an approvement of higher sensitivity by reason of a bigger Sd? Are 21" horns shorter than 18" horns to archive the same cut-off? |
no they arent shorter to reach the same cutoff. as a result of the larger diameter of the driver the horn is actualy longer. a TS 42 is ALOT bigger than the ab36 is. however its also got larger wheels and a bar handle so its actually easier to move aside from lifting it.
mykey ![]() Old Croc ![]() Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
pretty good if you want to shift some air below 40, otherwise stick to 12, 15's and 18's
airbell ![]() Registered User ![]() Joined: 11 June 2009 Location: Berlin, Germany Status: Offline Points: 279 |
Does anybody knows if the 108dB from the ts-42 are for 1/2, 1/4 or 1/8 space??
And if its for 1 speaker or more?
![]() coz the el-36c is claimed to have 106dB but at the prosoundweb shootouts
he didnt make a impressive appearance and didnt seemed to have
really 106dB 1w1m in general.he had a lot less output below 50hz than lab-horn in single...
pretty good if you want to shift some air below 40, otherwise stick to 12, 15's and 18's+1
exactly what we found
Balázs1981 ![]() Registered User ![]() ![]() Joined: 11 December 2022 Location: Hungary Status: Offline Points: 10 |
Porkolab BH 121 FLH. Ezt mi készítjük. Már PS Audio névvel. 21" Carbon fiber woofer.
Edited by Balázs1981 - 15 March 2023 at 9:35am |
Page 12> |
