21 inch long throw horn |
Page <1 78910> |
citizensc
Joined: 16 October 2015 Location: Perth,Australia Status: Offline Points: 547 |
Posted: 01 April 2021 at 8:38am |
I'm in the process of designing an 18 inch FLH to replace the SBH (the SBH is a design from the 90s, it was rejiggered to work with 'modern drivers' in like 2007, end result is badly optimised and doesn't work well with actual modern drivers).
I have been playing with the idea of designing a 21 inch FLH once I'm finished. A 21 has pretty much no advantage over an 18 in a FLH other than the fact that it can displace more air so can it take more power before it runs out of xmax. I might call it the 'Compensator' because... if you are not trying to compensate for something, why would you build it?? Should I actually design this? Even if it makes no sense, maybe it can be something for people who just want the biggest and baddest horn to waste their money on.
Edited by citizensc - 01 April 2021 at 8:41am |
https://www.facebook.com/voyager.system
@voyager_soundsystem |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 01 April 2021 at 6:35pm |
Lost count, of how many times, I've been completely underwhelmed by 21" FLH subs. I guess expecting solid 40hz, from stack of 4x cabs, is unreasonable. What I think would be really clever, is modding Martin WSX design, so it doesn't throw too far, for inside venues. A driver with higher Xmax, High BL, and maybe larger chamber in cab, would not require such a long horn,and possibly such tight throat/compression. Edited by levyte357- - 01 April 2021 at 6:51pm |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 01 April 2021 at 6:45pm |
Stuff some coats in the mouth.
KillBorrisWithBase
Joined: 16 March 2021 Location: Devon England Status: Offline Points: 8 |
Posted: 02 April 2021 at 12:19am |
Hi infrasound I’m new here I realy like the design you posted but can’t get the link to load for some reason, would love to have a go at building some of them any chance you’d be able to post drawings or anything please?
KillBorrisWithBase
Posted: 02 April 2021 at 12:33am |
APW i know a couple of cabs won’t play very low I’m just being realistic with my budget ideally I’d like to build 12 of them and I certainly would be re contributing them back into the scene I’ve already got a full sound system dedicated to the sw free party scene (although it’s currently in the nick after boxing day
KillBorrisWithBase
Posted: 02 April 2021 at 2:06am |
[QUOTE=KillBorrisWithBase]APW i know a couple of cabs won’t play very low I’m just being realistic with my budget ideally I’d like to build 12 of them and I certainly would be re contributing them back into the scene I’ve already got a full sound system dedicated to the sw free party scene
infrasound
Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2273 |
Posted: 04 April 2021 at 12:00pm |
https://file.io/58crMXmKFlpM
Dug the sketchup file out of an old HD. Disclaimer: No idea on origin or performance :-)
KillBorrisWithBase
Posted: 04 April 2021 at 8:06pm |
Thanks i Clicked the link, says the file been deleted tho
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 05 April 2021 at 1:08pm |
Before you try that, you might want to do some research into how subs actually work, and why they aren’t “throwing” the sub into the car park... Likewise actually conducting some measurements to figure out how you achieve what you like. You’d be amazed (or not) by how few people can identify low frequencies when they are actually being played. Conditioning and other factors typically mean that harmonics are considered as a fundamental, and many FLH will filter those harmonics out by their very nature. That doesn’t make them objectively bad, just not suited to your personal preferences. That said - yes, I agree - designs like the SBH are far from optimised. Hornresp usage seems to be the golden rule for many of these things; it’s a great tool, but it only tells a tiny part of the picture. If you want to see things done properly, you should look at Scott Hinson’s recent work on his dual 18” FLH over on the DIYRM Facebook page. Likewise, there are 21” FLH done properly out there. The stuff from Sean Hennessy, for a start. If you’re not keen on something the size of a Battleaxe, then the dimensions of the PG21XL he did for Pure Groove work too. Although loading those things is a pain in the arse beyond compare, even if you’re used to F218s... The other issue is the simple fact that thermal limits kick in well before excursion or otherwise. People push these things far too hard without considering the acoustic impedance of the combined horn, and the space that they’re placed in. Let alone the wavelengths involved. Judging a whole loading concept by a few DIY designs, most of which are invariably run without proper processing, is not doing anything remotely close to scientific analysis or engineering. Edited by toastyghost - 05 April 2021 at 1:09pm |
jacethebase
Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5837 |
Posted: 05 April 2021 at 6:44pm |
To be fair, changing the laws of physics would be very clever.
www.stage2sound.com |
RoadRunnersDust
Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 617 |
Posted: 19 April 2021 at 2:08am |
Apparently one only needs to travel West across the Atlantic to achieve that... it’s the only logical answer for some of the utter shite the treasonous swine come out with
toastyghost
Posted: 19 April 2021 at 10:53am |
A certain funky trousers man once told me that his subs were so powerful that they caused path divergence in photons, making the lighting at the venue bend. Yeah. |
Page <1 78910> |
