21" plans ? anybody got any good ones |
basenote
Joined: 18 May 2006 Location: United Kingdom Status: Offline Points: 25 |
Topic: 21" plans ? anybody got any good onesPosted: 13 April 2007 at 8:57am |
im about to embark on a journey of passion
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 13 April 2007 at 2:00pm |
Hi there
Have you looked here....
There should be some good ones there!
djstefanos
Joined: 18 November 2005 Status: Offline Points: 2355 |
Posted: 13 April 2007 at 2:23pm |
haha
moray james
Joined: 07 September 2005 Location: Canada Status: Offline Points: 141 |
Posted: 14 April 2007 at 11:14pm |
A typical 21 inch driver has an Sd of 0.1764 M2 while a 15 inch driver has an Sd of 0.0856, double that value and you get an Sd of 0.1712. So it would figure that a folded horn for two 15 inch drivers would be about right for a single 21 inch driver assuming that the driver T/S values are about equal. There are lots of dual 15 inch horn designs that should be applicable for a single 21 inch unit.
moray james
moray james
Posted: 17 April 2007 at 10:36pm |
Take a look here for some dual 15 inch bass horn designs.
moray james
basenote
Posted: 23 April 2007 at 2:35pm |
i'm to much of a rookie for the stuff i just want'ed a plan ready made and easy to put into action i have only had a few forays into the build world and i was hoping to come across something simple i may just have to go for the super scooper desgin
scoop chat on here gets amazinly heated hell hath no fury like a bass junkie without the plan he desires |
moray james
Posted: 23 April 2007 at 6:35pm |
Well regardless of what 21 inch design you find you will have to find out what driver was to make the design and so find out the T/S numbers of that driver if you want to substitute another brand of your choice. After that you build the box as designed but you cut for a single 21 inch driver rather than two 15 inch units. Unless I am way off base there should be no issues. If any of the guys out there with more experience than me can find a major problem with my assessment of the situation you should be just fine. This would get you a lot closer than trying to figure out the whole thing from scratch on your own. Build one up and see what you think about it. It won't be bad and you will get to learn something at the same time. Key parameters will be driver Fs, Qts and Le depending upon how high up you want to cross over. I would imagine that as a sub box that Le will not be an issue in this application.
Rog pointed out (else where) that this type of design is really just a big vent reflex design (BVR) and as such should be fairly forgiving of driver values just so long as you are close. Once built you can play with the back cavity volume (add solid fill to make it smaller) and the throat size (use strapping to make it smaller). You should be able to fine tune it to what you want just playing with those two variables. Regards Moray James. Next best option would be to rent something that you like for a night then open it up and copy it. Not the classiest thing to do but it will get you where you want to be as fast and as inexpensively as you can. |
moray james
moray james
Posted: 29 April 2007 at 9:22pm |
I just discussed this idea with someone who has eperience with cabinets like this and was advised that it would probably be better to scale an 18 inch cabinet design up by three inches overall. Ther are a number of 18" designs atound to choose from. Also you might consider Rog's 21" Super Scooper design (I forgot about it) which ought to give you lots of room to play with with what ever drivers you might consider. I have not searched but I would be surprised if there were not a bunch of threads on Rog's Super Scooper design with respect to driver selection. Hope this is useful informaion. Regards Moray James.
moray james
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 17 May 2007 at 12:46pm |
Just had an idea, reading all this Mini 18" scoop business
Can you make a Mini 21" Super scoop version ??
Sticks n Stones
Tekasis
Posted: 17 May 2007 at 12:55pm |
One of the members did, which then made them the size of a standard 18'' scoops.
or do you actually mean as short as the 18'' mini scoops ?
CHAMPION
Posted: 17 May 2007 at 3:07pm |
I mean a 21" mini scoop !!
i have 2x PD2150 driver, i would rather make a smaller scoop because of it size and weight and i dont play too much dub roots music Edited by CHAMPION - 17 May 2007 at 3:08pm |
Sticks n Stones
