21" Ported Horn design idea |
Page <1234> |
Arcy12
Joined: 07 September 2018 Status: Offline Points: 12 |
Posted: 01 April 2020 at 12:23pm |
Hey dude I'm keen to put one of these together, could i have a cut list and routing details.
Cheers |
NiToNi
Joined: 17 February 2017 Location: London Status: Offline Points: 17 |
Posted: 14 May 2020 at 12:59am |
+1
Would love to have a go at this mate! ... although slightly lower corner at 27 Hz would have been perfection
Fracture_clinic
Joined: 01 November 2018 Location: Norwich Status: Offline Points: 113 |
Posted: 14 May 2020 at 1:38pm |
I cant install Hornresp on my machine (admin issues) can anyone speculate these changes please?
1) larger chamber all else the same 2) larger chamber and horn extended through 90 degrees (over the port exits) and along width of box. Assume ports are relocated + ignore external dims for now. 3) Same as above but with chamber remaining the same. Asking a lot I know - until lockdown is over I can't jump on a buddies laptop to try myself. Not asking for sims just interested in bouncing ideas around. TIA
Edited by Fracture_clinic - 14 May 2020 at 1:40pm |
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 30 July 2021 at 4:00pm |
Kevin, we would like to build your ported horn, any chance of getting a set of plans?
smitske96
Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1217 |
Posted: 22 November 2021 at 8:42am |
Looks like a similar idea: http://https://www.seeburg.net/en/customsolutions/ps-sub/175
smitske96
Posted: 29 November 2021 at 9:38am |
Am I correct in thinking that they tune the BR port high and the horn low?
In all other quick sims, I can not reach such 2,83V sensitivity figures.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 29 November 2021 at 9:52am |
I would treat the Seeburg as a variant of tapped horn, rather than a rear ported horn. It’s very dark in the renders, but I have a feeling that the driver ‘vent’ also opens into the horn mouth based on a similar design I saw elsewhere. Also that’s the peak sensitivity value in the specs. Not the average. Edited by toastyghost - 29 November 2021 at 9:53am |
smitske96
Posted: 29 November 2021 at 1:40pm |
Yes, but it even has a similar/higher sensitivity @50Hz than for example a BC218.
According to the measured response peak sensitivity is around 111/112dB @+-150Hz, which does fall out of the desired bandwidth but still is pretty high. If I may ask, which design are you talking about regarding the vent also tapping in the horn mouth?
bob4
Posted: 29 November 2021 at 4:29pm |
Isnt that very unlikely, since you need lab horn size for real 30 hz horn loading (in multiples of four!!) I would have guessed the reverse
![]() Edited by bob4 - 29 November 2021 at 4:29pm |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 29 November 2021 at 7:36pm |
That Seeburg box looks like the old Martin Audio ported horns.
AlphaC
Joined: 02 February 2022 Location: Germany Status: Offline Points: 8 |
Posted: 02 February 2022 at 1:52pm |
Which Martin model do you refer to? I'm not aware of any similar design.
smitske96
Posted: 02 February 2022 at 2:24pm |
@bob4
2,6m seems doable with those dimensions.
Page <1234> |
