  New Posts New Posts RSS Feed - 21" version of TRS-218
smitske96 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 8:34am
@snowflake
They probably use the 21NLW9601-04.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 10:05am
Originally posted by FOO FOO wrote:
If I get the time this upcoming weekend, I can measure them. It will be outside on a grassy field. 6 each side in end firing setup, 3 layers of 2.
But one box could be plugged in on its own for measurements.
But they don't disappoint. 27hz is real. Not f3 real, but they do get down there.
And can't see why it's a problem with the program power?
I suspect that there is a lot of EQ boost in the DSP settings to get significant 27Hz output - would be interesting to see raw response without DSP applied.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 10:06am
Originally posted by smitske96 smitske96 wrote:
@snowflake
oh yes probably is. For some reason the -04 version isn't on loudspeakerdatabase.com
FOO View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2023 at 12:23pm
I can bypass the DSP if we got time for it. Could be fun to see raw vs processed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 11:01am
did you get any data?
This page was generated in 0.281 seconds.
