  New Posts New Posts RSS Feed - 21" X1
21" X1
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Topic: 21" X1
    Posted: 13 October 2006 at 5:16am
Anyone made a 21" X1 ????
Got some 2150's
Sticks n Stones
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2006 at 12:08pm
I'm sure it wouldn't take much playing in WinISD to design a suitable enclosure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2006 at 3:07pm
Can anyone help me on a design for the 21'' X1 ?
Sticks n Stones
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 3:44am
So what kinda help do you need?
Wkr Johan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2006 at 8:30pm
I need a design or  The plans for the 21" version of the X! for the PD2150.
CAN ANYONE HELP !
Edited by CHAMPION - 27 October 2006 at 8:35pm
Sticks n Stones
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2006 at 5:42pm
Champ,
the void link u put up top, gives the outside dimensions of the Void cab, take these as a guide and adjust the orginal X1 plans to suite the bigger cabinet,
its not as hard as it looks
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2006 at 7:51pm
USE WINISD!
It should have the 2150 params in it already.  Start with something like 250L tuned to 30Hz for the rear chamber and about 80L tuned to say 75Hz for the front chamber and adjust from there.
You're looking for a response which is mostly flat, maybe 1-2dB dip in the middle at most. Adjust for trade-off of extension vs efficiency vs bandwidth vs cab size.
Edit: just had a quick play.  250L,30Hz and 100L,60Hz looks ok.  It's gonna be a big cab though....  f3@30Hz is quite useful...
Edited by ceharden - 30 October 2006 at 6:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2006 at 4:39pm
thanks, im not too familiar with WINISD,,ceharden can you give me some sort of dimensions?
Thanks
Sticks n Stones
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2006 at 4:50pm
Contact Shortman,
I'm more than sure he built some for Matrix a good while back which was on E-bay.
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2006 at 6:23pm
that looks like a heavy lift! 88kg so heavy-ish!
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2006 at 8:57pm
Honestly, use WINisd or bassboxpro, its a piece of piss if you can actually be bothered to put a moderate amount of time in.
Horns are more difficult, reflex or bandpass boxes are easy with the software.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2006 at 12:19pm
hey its not only easy but very fun!!!
i have winsid question???  how do the vents work/  and if they say a negative number does that mean its impoosible?
