  New Posts New Posts RSS Feed - 21DS115-4 6th order bandpass design - port flares
Larry23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry23 Quote  Post ReplyReply Direct Link To This Post Topic: 21DS115-4 6th order bandpass design - port flares
    Posted: 21 March 2026 at 12:48pm
Hi folks,
I’ve been working on a design for a new 6th-order series bandpass enclosure using the 21DS115-4, and I’m pretty happy so far. The design is relatively compact out of necessity, with a total internal volume of around 200 L including ports, driver, and bracing. -3 dB points are roughly 35 Hz and 110 Hz.
I’ve started looking more closely at the port design. Air velocity isn’t an issue, but I’d like to incorporate something more than simple, straight rectangular ports.
Many commercially available designs, and those from 18 Sound/B&C etc. incorporate angled or flared sections within the ports, both internally and at the exits. Is there a reliable way to sim/calculate how these affect tuning?
I’m considering an exit with a 10 cm, 45° flare on one side leading onto the front baffle, while the other side remains flush against the side panel. Is there a method to predict how this kind of asymmetric flare would influence the effective port length/vol and tuning frequency?
Thanks in advance Smile
Edited by Larry23 - 21 March 2026 at 1:04pm
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2026 at 1:24pm
AFAIK, the only freeware tool for working with flared ports is the optimiser developed by user "stv" over on DIYAudio: https://www.diyaudio.com/community/threads/investigating-port-resonance-absorbers-and-port-geometries.388264/
I don't know if it works with the specific combination of shapes you describe or not though.
HTH,
David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry23 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2026 at 1:35pm
HTH,
David.
Amazing, thanks David.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:35am
what's going on with the specs for the 21DS115 ? B&C have updated the specs for the 8-ohm version and removed the spec sheet for the 4-ohm version. The 8-ohm spec sheet now says the Fs is 36Hz but the impedance plot shows it is 30Hz.
21DS115 8Ω - LF Drivers - B&C Speakers
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 19 minutes ago at 6:01pm
Spec sheet on website states fs = 34 Hz, this matches peak in impedance plot in same spec sheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 15 minutes ago at 6:05pm
they must have updated them both last night LOL. 4 ohm page is back up too.
