  New Posts New Posts RSS Feed - 24" driver in horn?
24" driver in horn?
Ray666 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray666 Quote  Post ReplyReply Direct Link To This Post Topic: 24" driver in horn?
    Posted: 17 January 2007 at 1:14pm
i just tough that have anyone ever tried to put a 24 " driver in to a horn? would it even fit and how long would the horn be??im not that smart to make the calculations for horn yet so im asking wiser men the advice.
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2007 at 9:10pm
its possible, but theres many problems with it.
firstly, the drivers are bloomin expensive (only one i know is the PD124). these weight stupid amount on their own.
put these into a horn, and it will be the size of a full height wardrobe, at least 150kg of wood per unit alone!
then theres the 'advantages', altho its rumoured you will end up with fuller fatter tone, for the equivilent cab size and driver cost, you can easily have 2-3 18" versions having a larger louder output, better power handling and are easier to move (seperate cabs instead of one mass).
so id say, if your a rich c**t installing your private basement club out, then by all means make some to install, otherwise stick with single 18" horns!
cheers, Pat
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2007 at 3:45am
Moved, because whilst that would be horn porn, its not a Porn Horn!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2007 at 4:33am
The larger the Sd of the driver, the shorter you can make the horn path length for an equal cut-off. So it can extend pretty good on a band pass horn. Still it would be big because of the relative low compressionfactor (horn begins already big).
Wkr Johan
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2007 at 5:04am
TSW 124
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2007 at 5:16am
it's possible, but no point to it. if you went that route i hope it's a perma install and not something you will be move 3 times a week...
take the PD2450... huge and is in the TSW 124 i do believe that Mykey posted. i would still go for 4x 18's vs 2x 24's though...
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray666 Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2007 at 2:46pm
:) ouhhhh jeaaaahhhhh :D i love big speakers - i think about that basement thing you mentioned about Pat - i have full basement under my house about 100 m2:D:D:D so i am realy considering of making a "sound room" down there :D oh it will be funnnnnnn ... imagine the horns made out of concrete :D and the mid tops to - i think im going to build this room a very long time - its going to happen in the future - i`m sure of it:D
Peace!!!
Raimo;)
Edited by Ray666 - 11 April 2007 at 2:49pm
intrancer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote intrancer Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2007 at 3:30pm
LF H1024
Low frequency system - front loaded horn design – passive
Designed to extend the low frequency range of long throw mid-high frequency systems at high sound pressure levels.
Applications
The LF H1024 finds its application in systems for:
distributed sound reproduction: e.g. large clubs and dance halls
sound reinforcement: e.g. medium to large concerts, large musicals, operas and circuses
Description
The LF H1024 is the largest member of the horn loaded low frequency systems. The system is designed to extend the low frequency range of long throw mid-high frequency loudspeaker systems. Delta Loudspeakers SA is one of a few professional loudspeakers manufacturers that provides 24 inch low frequency systems.
This system is based on a 24 inch transducer with a 160 mm voice coil integrated in a sealed enclosure and coupled to bended horns. The horn design is inferred from a snail-shell. The mouth opening covering the complete front of the cabinet assures a low cut-off frequency. The enforced enclosure is manufactured with 24 and 48 mm Finnish birch plywood glued together in conjunction with dado joints to assure the highest quality of robustness. The black textured semi-matt paint makes the enclosure water repellent. The horn is protected by an aluminium grid with octagonal holes, designed for maximal strength and acoustical transparency. The removable foam attached to the grid protects the system from splash water and dust. Two Speakon® male connectors assure reliable electrical connections and the possibility to feed the signal through the system. Four large recessed steel bar handles and wheels mounted on the rear panel assure comfortable carriage. The system is optionally available for fix installations without wheels and handles.
Related and complementary products
Following complementary mid-high frequency loudspeaker systems are recommended for a well-balanced sound sensation:
mid-high frequency horn systems: MH H2010 and MH H1010 (long throw)
line arrays: LA 2005 and LA 2005SP (self-powered)
amplifier: AMP 2000 (bridged mode)
Related products:
low frequency systems / horn: LF H1021
low frequency systems / vented: LF HR1024
rich, ind.st View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich, ind.st Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2007 at 4:05pm
Peace!!!
Raimo;)
build some imperials :)   --- www.decware.com
music is god
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2007 at 7:04pm
Bad idea which is quite perfectly explained here.
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=1130
Stu
eAddOnload(bmi_load,"bmi_orig_img");//-->
All you need to know is:
My acts:
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2007 at 4:15am
While were on the subject...someone come up with plans for the PD 2150's 21" Drivers !
Sticks n Stones
opus jody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote opus jody Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2007 at 4:41am
i thought the subject was 24's . Norty 'll smack your botty!
worth checking the beyma 21" out too, for horns. it does need treating though, to stiffen the paper, particularly on the 1st rib out from the centre.
Edited by opus jody - 12 April 2007 at 4:44am
Improvised Hardware Music http://vimeo.com/user9389813/videos
