  New Posts New Posts RSS Feed - 24V Bluetooth Speaker
Jebimasta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jebimasta Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2018 at 8:57pm
Like I said, not an efficient way of making it, but that's not the point.
Originally posted by I-shen Soundboy I-shen Soundboy wrote:
With the relatively cubic design, v2.0 could be knocked up with a bit of standard cabimetmaking.
How boring Wink
The fine line is an interesting idea, but I like it as a byproduct of the construction.
lost eden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost eden Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2018 at 8:42pm
Originally posted by Jebimasta Jebimasta wrote:
I'm actually not so sure about the battery charging bit... I've used a lab power supply set to CC/CV mode and it charged fine. I'm guessing a boost board that does the same thing will also work. I'm assuming it will work as a normal power supply when the speaker is plugged in and on/working. How it interacts with a full battery is a mystery to me hahah.
I know lots of other people have done this before, wonder how they did it?
Are you taking into account that a lithium pack should be balanced by the charger after the constant current & constant voltage phases are complete?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jebimasta Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 12:41pm
Eden,
Yeah the battery protection board has a balancing function and it appeared to do the trick when I used the CC/CV lab power supply.
Just a little update, I've not done anything for a week or so, tidied up a bit of wiring but that's about it.
I've decided that rewiring the bluetooth status LED was too much of a pain in the arse so I'm using a photoresistor splodged on top of the existing LED to turn on a transistor and light up the switch that way. should have that circuit sorted sometime next week and I can concentrate on applying some finishing touches!
