24v System help needed |
Thomas Hosker
Registered User Joined: 20 June 2012 Location: East Sussex Status: Offline Points: 493 |
Posted: 22 April 2013 at 10:45pm |
So im looking to build a amplifier pack for use with some of my smaller speakers, id like to run this off a 24v battery supply for free partys, BBQs and general summer fun. I have a 12" Flare Audio horn loaded sub/kick bin and a couple of Flare Audio V65 tops. The sub has the driver from a DAP Clubmate 12, its rated for 100db/w/m (half space) and im abit unsure about the drivers to use in the tops but it will probably be some random 6.5" driver that are rated for 115.8db @ 1m.
Ive been looking at these sure amp boards, what do you guys think? Amp for tops - http://www.ebay.co.uk/itm/2-X-150Watt-Class-D-Audio-Amplifier-Board-TAS5613-150W-Stereo-Power-Amp-/110985499517?pt=Lautsprecher_Selbstbau&hash=item19d740537d Amp for sub/kick - http://www.ebay.co.uk/itm/1-X-300Watt-Class-D-Audio-Amplifier-Board-TAS5613-/350601582262?pt=AU_B_I_Electrical_Test_Equipment&hash=item51a17b96b6 Apart from batteries what else do i need to make this work? Are there batter amps i could use? Do i have enough power? Hellpppppp :) |
WWW.T8Audio.Com
