2x10" vented horn idea |
Post Reply | Page <1 23456 9> |
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
I like a challenge
of course it's easier to build, cheaper, lighter and smaller. but... i rather have 2 horn loaded cabinet i can use till many 400 people. I've got 4x mogale super scoopers 18 and 1x 18" reflex cabine both fane 18xb loaded For small gigs i use them in combinatie with my HK pro 12. bigger gigs 2 or 4 scoops with the horn tops. The reason i start thinking about a different cabinet was. i was playing at a wedding there where about 150 people and the hk's we used where just not load enough. i could use them for a venue max 120. but using 2 scoops with the horn loaded tops looks to big for a wedding that's why i want something i can fly is not to big en more then load enough. And i like to try to make something new
bass*en*mass
hmm, 210s with those faitals and suitable 1.4"s+horns will be louder, yet more balanced, than your hk tops.. you have 4x 18" reflex subs with 18xbs+4x scoops? if so you could possibly use the reflex subs on their own with 210 reflex tops on sticks for most stereo setups+mono sub scoops 2-4 if required?
Noud
I’ve got 1 reflex 18xb and 4 scoops 18xb
But de 210s will only play to a venue of max 200? Why not build a hornloaded cabinet that usefull till maybe 400? I know they will be bigger and harder to build but i think useable for almost every gig. ( my gigs ) |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
tbh, that is a lot of wasted space, and too many angles. It's going to take ages to build. The Peter Morris layout is pretty much perfect, simple and efficient. All the wasted space, complicated angles and redundant walls disappear, just by putting the baffle and horn throats to the back. |
Noud
Yes that's true i still need to work on a better layout. Peter did a perfect job! really good.
If I've got some extra time i'm going to work with it. One question about the Peter Morris speaker, is it a offset horn? |
bob4
Slot loaded front loaded horn, with br port to achieve more low end
Noud
Okay maybe a stupid question but in hornresp there's no difference ? Just simulate a front loaded horn?
It looks a lot like offset I'm going to try getting the same cant of layout
bob4
Im no expert by any means, but afaik offset horn would be a driver mounted directly into the side wall without front chamber, meaning that different parts of the transducer have differing offsets from the horns start. The peter Morris, and your plan both have a front chamber with slot loading into a folded horn
Noud
A lot less Corners
This need a little tune up (low mid horn) also the chamber is to big but that can be fixed. Next time i will fit the horn and driver. Not the final drawing yet. Could this work? what do you guys think? |
bass*en*mass
noud:
-crossing scoops above 100hz straight to a top will likey sound weird due to phase issues of scoops above about 90hz.. ideally you would need a dedicated kick cab to fill the gap -the 10" horns wont be useable much above 7-800hz, without proper phaseplug to reduce front chamber likely not even above 500hz.. so be prepared to buy suitable/expensive 1.4" HF and large horn to make them work+take care of the horn expansion, throat compression/front chamber -your attempt/idea being much smaller than the PM cab will also lead to less horn loading below 250hz, leaving a wider gap between horn cutoff and optional reflex tuning, overall output 100-250 will be way less than using 12" drivers and larger horn -the 10fh520 is not exactly a mid horn driver either hence the response wont be great/balanced but rather peaky (as already sort of visible in your sims) |
gen0me
For your case low frequencies = entire bandwidth. If you place top horizontally it would have reverse dispersion. Thats why P Morrisons top is higher than wider. For your bandwidth you could bend this horn as you like. Ill be carefull with the simulation here. |
Noud
I Premairly want to use the speaker horizontal so the dispersion should be fine is i understand it correctly. the sub could became a new project.
but first try to make the best of the faitals. I would like to buy the bms 4593he for this cabinet with the rcg hf950. so í'm aware it will be expensive. hornresp now shows me it will work till about 600hz so the horn should work? I'm now professionel but i want to try making this work. I'm aware it's not easy en there needs to be compromises Looks like i'm missing the point why this design will not work Edited by Noud - 11 January 2018 at 7:00pm |
