2x10" vented horn idea |
Post Reply | Page <1 56789> |
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
Some Build pics so far
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Wow, top work, you are a master router!!
Inspirational stuff!
Noud
Thanks Bob!
One step at a time to get the best result Still looking for the right amp and the hf driver protection hf filter. -Amp should have 1.5 รก 2 times the power of the speaker (1800-2400watt 8ohm 3600-4800watt 4ohm) -The FP14000 look perfect for the job! but do i need to be careful pushing it till 0db or peak? (it's so much power for the small speakers) -For the hf filter 500hz would it be better to make it 2ndt, 3rd or 4rd or just 1st order? it will be active filtert at 650hz but just for safety a extra passive one. |
Noud
Small update.
I've order all small part: nut's. bolts. foam, and, and..... all part are milled so i can start assembly next week wen all parts are there. I made a dissension on amps ore the fp14000 or a ma12000I. Wat do you guys think is better? for my application? I like the ma12000i because of the power and the functionalities. (cheaper) And the Lab gruppen should be good power wish but less to play with I haven't got any experience with neither of the amps. I also ordered a capacitor of 33 uf for protecting the hf driver. (got some small one to add when necessary)
Noud
So the build finally ready! The next project will be some compact (max. 350L) subs instead of my 18xb super scoopers. Options: Alt-config 15 (can be found on facebook High Order Quarterwave Society (DIY Paraflex & Super Planar dev community)) Cubo sub |
bob4
Congratulations, they look amazing!!!!
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
Excellent carpentry skills. Best Regards,
JonB67
Yes they do! They look amazing. I might be after something similar. Where is the plan from?
Edited by JonB67 - 16 February 2020 at 7:27pm |
Noud
Thank you guys! very happy with the result!
They are copies of the Seeburg K20. on there site you can find the 3d file, and you only need to fill in the baffle and bracing. |
Bams
Young Croc Joined: 08 April 2009 Status: Offline Points: 622 |
Erhm... might be a sticky question.. but is Seeburg okay with people copying their commercial available designs?
Nonetheless... really clean build!
Edited by Bams - 17 February 2020 at 8:47am |
JonB67
How did you do the grill? Final product looks really well done.
How does it compare to a d&b q7? Does it need lots of processing ?
Noud
Thanks(1)
Thanks!
I work at a stainless steel factory where they have a cnc lasercutting machine Never heard or used the Q7. It doesn't need a lot processing but this is based in my garage. Coming weekend i will do some more tests with 4 in a large barn. |
