2x10" vented horn idea |
Post Reply | Page <1 789 |
NeuroWinter
New Member Joined: 08 November 2014 Status: Offline Points: 1 |
Looks amazing, awesome pictures and great build!
Is there a cnc cut sheet around anywhere? |
Fsurfer
New Member Joined: 22 January 2021 Location: UK Status: Offline Points: 8 |
Amazing thread I would love to redesign the pair of side firing floorstanders I use at home, but space is a premium and the neighbours are too close
Edited by Fsurfer - 24 January 2021 at 8:22am |
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Online Points: 838 |
A 15” with a bl of 38,7...I can understand that thing will sound like a beast
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
Sorry no cut sheet available.
Yeah they sound amazing! the output at 40hz make them sound like a big box and still have a great punch when the kick hits! I'm still planning a test day to test them in different room. also to test the full set 4x k20 and 4x altcon 15 at high spl Earlier this week I download a demo of Smaart DI2 and learning as much af I can before test day. Maybe when the current situation is getting better I want to take a course en buy the software.
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
If measuring on the subs extensively, I would advice to do that outside (the less buildings the better).
Some CEA2010 burst tests would be interesting on those paraflex designs.
Noud
Its been a wile but I finally dit a off axis measurement to the main speaker.
1m above the grill, outside, on its back on the ground. on axis 15dg off 30dg off 60x40 horn |
AlphaC
New Member Joined: 02 February 2022 Location: Germany Status: Offline Points: 2 |
Nicely build. And I'm honored that someone took my design as inspiration and model. But for what reason is the external appearance copied in such detail (including cutouts and railings not needed in the passive version and mounting points for original accessories you probably don't have)? And why is the name identical to the original model? The speaker components are not the same as in the original anyway.
Noud
Thank you for this great design! I like it very much!
I made the railing to have the option te use the flyware. In the future I will buy the Seeburg multirig. There’s no real reason why I used the same name. I don’t know what the original components are. I had the faitals already I they seemed to be a good match. Out of curiosity witch driver are in the original?
Daddy Culture
Registered User Joined: 02 August 2014 Status: Offline Points: 22 |
Load the SCOOP with a B&C 18DS115... then make the test again
The Paraflex is great, but it was unfair compare a DS115 against a Fane 18XB, the B&C has a much stronger motor.
Edited by alehmarques - 14 May 2022 at 1:47am |
Daniel Skrotzki
New Member Joined: 01 February 2024 Status: Offline Points: 1 |
Könnte man gegen Geld den Plan haben ?
bob4
Les mal bitte ein bisschen weiter oben den Beitrag vom user "AlphaC". Er ist der Entwickler der hier kopierten Box und fand es eher uncool dass der TE seinen Nachbau auch noch haargenau wie das Vorbild benannt hat, mit gefräster typenbezeichnung auf der Anschlussplatte etc... PS: Forensprache englisch......
Edited by bob4 - 02 February 2024 at 7:47pm |
