2x12" angled mid - drivers |
thanosvas
New Member Joined: 18 June 2019 Status: Offline Points: 8 |
Posted: 18 June 2019 at 10:18pm |
Hello everyone ! I am about to start build the following mid speaker from Fane, https://s345.photobucket.com/user/thanosvas/media/1_zps79g5ursn.png. - http://s345.photobucket.com/user/thanosvas/media/2_zpssxyktvaa.png. - which I want to x-over it at 180-200 Hz. So I would like to know if the choice of using Fane Sovereign 12-300 drivers would work well. This is cabinet's supposed to be short throw so I am not sure if I have to use drivers suitable for horn applications. Do you have any other suggestion ? Thank you in advance ! P.S.1 I also keep in mind that I maybe customizing it to a vented enclosure by opening 2 or 4 small holes. P.S.2 Sorry if this is already being answered somewhere else, I am new here and I couldn't find any similar posts
JonB67
if you port it will probably want a little more volume. Suggest you sim it in winisd or similar to work out the volume and port sizes and adjust the plan accordingly.
Edited by JonB67 - 19 June 2019 at 7:45am |
Earplug
Thanks(1)
No point porting if you are going to xover that high. I had a couple of those years ago - loaded with some Celestion, but can´t remember the model. Just try find something with a good midrange response & decent sensitivity. The Sovereign 12-300 should be fine. |
thanosvas
Thanks for the answer mate! Actually I have simulated the sovereign 12-300 and it seems I get the exact results I want. However, my only concern is the sound dispersion. Should I get a driver with more EBP ? Because this enclosure's supposed to be a short throw
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
Earplug
Yes - I wouldn´t overthink this. The cab is designed to do a specific job. If the Sovereign sims are good, just go with that! |
toastyghost
‘Short throw’ just means ‘no pattern control’ and ‘not that loud’
thanosvas
Oh, I didnt know that. That's a useful info. So I guess I will stick with Sovereign 12-300 or with drivers with even better sensitivity and mid response. Thank you all for the help guys. I really appreciate it :)
Earplug
All your 'basic' front-loaded cabs suffer from that (bad pattern control) - but don´t have to be 'not that loud'. You can get a decent dB level as long as you go for drivers with good SPL at their designated frequency range. |
