  New Posts New Posts RSS Feed - 2x8+1" for Bass Guitar
rhuet99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhuet99 Quote  Post ReplyReply Direct Link To This Post Topic: 2x8+1" for Bass Guitar
    Posted: 28 March 2013 at 10:28am
  I am wondering if anyone has built a 2x8 +1" cab for bass guitar.  A friend has a GK RB800 that is Bi-amp and is looking for a cab to handle the top end.  The amp delivers 100w to the dedicated  high output and has a variable x-over.  GK suggests starting with the crossover set to 500hz. The bottom end is a single 15" EV copy loaded with an Eminence 3015LF
  I am considering a Faital Pro 8" 8FE200 as a candidate for the 8" cones.
Any suggestions or links to a previously built DIY cab of this sort would be appreciated.
VisualShock View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote VisualShock Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2013 at 11:44am
There are eminence and celestion drivers with a closed back requiring no chamber.  They are designed specifically for 500hz+ applications, such as bridging gaps between (for example) a 15" and 1".
 I have a pair suspended in front of 15" drivers in my 2x15.  Took a bit of work, but I recessed the 15s about 5mm, cut out, inverted and re-glued the dust-caps and then bolted the 6" drivers to the grill.  The result is a somewhat co-axial effect (in the loosest definition of the term).
Before I decided upon that idea, I had toyed around with making a cabinet similar in dimensions to the 2x15 to house the MF+HF.  My plan was to use closed back drivers and utilise the rest of the space as cable storage or as a case for a pedal board.
