2xpunisher plus Walt stepped horn |
nomis
Joined: 07 January 2008 Location: France Status: Offline Points: 538 |
Topic: 2xpunisher plus Walt stepped hornPosted: 24 January 2008 at 10:32pm |
i realise the stepped horn design by walt on the speakerstore site is not intended for p.a. but what does anyone think about one on its side between two punishers for a small rig?
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 24 January 2008 at 10:41pm |
just build more punishers
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 24 January 2008 at 10:44pm |
they do an almost similar job, the tapped will go lower, and the punisher will be a bit louder id think. use one or the other.
insert silly sentence here
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 25 January 2008 at 10:10am |
It is a very simple build though. I'd be tempted to give it a try with some of the wood in our lockup and a spare Ciare.
Not sure how good it'd sound at a distance though. |
james folkes
Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
Posted: 25 January 2008 at 1:36pm |
i built a double tapped horn based on walt's design to use as a sub with the martin rig, sadly the drivers got blown up in something else before i had had much chance to see what it did. air was moved however at the one event where it got a good beasting. what i would be tempted to try was a pretty much direct educated guess copy of the danley single 12" with the driver in the middle of the horn (more like a tapped horn proper?) and with the opening on the end. better still would be trying to re-fold it to emulate the other single 12" danley sub. i am still looking into this as an option for completing the martin system, along with wicked ones and a modular bertha. all good fun. anyway, they do play notes that the punishers don't reach, but are better matched to a bass bin optimised to play in a higher passband, such as the usb.
james. |
mardy hippy.
xlogic
Joined: 21 August 2006 Location: London Status: Offline Points: 565 |
Posted: 12 February 2008 at 4:42pm |
hands off me wood! thats for xtros |
rich, ind.st
Joined: 14 January 2005 Location: United Kingdom Status: Offline Points: 1096 |
Posted: 29 February 2008 at 2:06pm |
i've used the stepped horn outdoors once but didnt really get to turn it up very much, i did consider it'd make more sense for PA if it exited from the end rather than the side but would mean a stupidly deep stack |
music is god
