  New Posts New Posts RSS Feed - 3 piece mt122
3 piece mt122
trentp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Topic: 3 piece mt122
    Posted: 04 April 2010 at 11:18pm
i would like to build a 122 in seperate pieces for stacking purposes. is this logical and how do i do it.
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 12:09pm
Just take 1 part and build like the drawing but then as high as only 1 piece, keep all boxes the same with and depth so that they're easy stackable.
soundguymatt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundguymatt Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 1:49pm
i'll be doing the same soon - will let you know if i draw up any plans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2010 at 8:49pm
a while ago i wanted to do thesame i have a plan of the mid-horn part the high part the same and if it isn't you must adjust the height:
jonny4288 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonny4288 Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2010 at 11:23am
Had these built from tom at stable audio a while back; certainly works well split,
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2010 at 7:21pm
nuff respek
