  New Posts New Posts RSS Feed - 3 way dual 12 inch tops
Foca_Dacian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foca_Dacian Quote  Post ReplyReply Direct Link To This Post Topic: 3 way dual 12 inch tops
    Posted: 05 July 2020 at 1:06pm
I am working on a better design for my tops and I came up with a 3 way double 12 inch top.
My current double 12 inch tops that I have built https://forum.speakerplans.com/tilted-tops_topic105463.html have some flaws (shitty disperion from the 12 inch speaker not coupling corectly above 500 Hz, x-over center point between mid and high is @ 1 KHz.
This is what I came up with:
in this design at the top of the speaker there is Limmer 870qx horn that will take care of 500 Hz and up, below that , two 12ndl76 that will work in 65 liters 90-100 Hz to 500 Hz.
Also I have taken into consideration Limmer 042 horns( would prefer this one because of the wider dispersion than the 870qx) , but 042s make the speaker a little to wide and I can not keep the internal volume @ 70 l as i want for my 12ndl76 (speaker has to be very shallow in depth) , I tought of putting the 12 inches in a V config like the RCF 4pro6001 speaker but I have no ideea of the interaction betweeen the speakers in the V positioning, that would not make the speaker as tall as it is with front baffle positioning of all components.
what do you guys think? how would you aproach this design?
Edited by Foca_Dacian - 05 July 2020 at 1:06pm
