3 Way horn top |
| Author | ||
ScandicViking
Topic: 3 Way horn topPosted: 21 January 2014 at 12:04pm |
Hello
I stumbled upon some pictures of a 3 way top the other day. But I couldn't find the find the plans for it. So I would just like to know if anyone has got them ![]() From what I know, It uses a 12" for the LF, 8" for the mid in a RCF H6000 flare and a 1" HF. Here's the pic
![]() Edited by ScandicViking - 21 January 2014 at 12:09pm |
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Posted: 21 January 2014 at 12:08pm |
doubt the low/mids meets the mids properly...
(would need to be crossed higher than they play well) |
all bass
Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1845 |
Posted: 21 January 2014 at 12:10pm |
The 8" flare looks like the RCF H6000 Phase Plug Horn for MR8N301
ScandicViking
Posted: 21 January 2014 at 12:20pm |
I'm pretty sure it is the H6000 with a RCF MR8N301 driver.
Teunos
Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1832 |
Thanks(1)
Posted: 21 January 2014 at 12:30pm |
Best regards,
Teun. |
ScandicViking
Posted: 21 January 2014 at 12:32pm |
Thanks alot!
Cheers
all bass
Posted: 21 January 2014 at 1:36pm |
He uses very nice components, shame that all but his 3way top are made from crappy fibre board. His grills are quite nice. ![]() |
corell
Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1159 |
Posted: 21 January 2014 at 1:39pm |
+1 the mid horn is to short |
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 21 January 2014 at 1:41pm |
slaith
Joined: 30 December 2010 Location: Sweden Status: Offline Points: 73 |
Posted: 02 February 2014 at 9:16pm |
Are they supposed to be standalone boxes?
Because if not then the hybrid horn priciple is totally redundant. Small closed box and you would have something, the port addition will be almost none att crossover around 80-100hz. And also I would put the treble horn as close as possible to the mid, make then act more as one source. But the idea is a good one, and it seems fairly compact too. What are you guys thoughts on the fairly uneven load on the cone?
