3 way or 2 way Project |
csijo
Registered User Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 102 |
Posted: 07 May 2019 at 11:55pm |
Friends of www.speakersplans.com thank you very much for your continued support
I want to design a speaker project, to manufacture and take advantage of a batch of components, since I have 12 units JBL M115-8, 12 units FANE Colosus 12MB MidBass, 8 Drivers Eminence PSD2002, 8 Drivers Lanzar Pro D220S and 10 drivers JBL 2412H. I have a small sound company and I usually attend events such as weddings, 15 years and sporadic sound for music groups or bands. I own 12 Sub Bass boxes type RCF ESW1018, 6 with Eighten Sound 18, 4 with Fane colossus 18Xb and two with PRV 18. So I was thinking of two options to make: A) Construct 6 boxes 2way using the same components that is 6 boxes double 15 and 6 boxes double 12, two drivers in each box. B) Construct 12 boxes 3way using a MidBass 15 JBL and a MidBass 12 and two or three drivers for each box and you can stack them in 6 per line vertically or horizontally as a line array system. My idea would be that if at some point I have to cover a large outdoor event, something like 5,000 or 10,000 people, I should have the ability to attend, and at the same time I can also use these speakers at the simplest events. Some boxes that are compact and that do the job. What I would like is to obtain the largest possible SPL of these speakers. Here I show you some designs to listen to your opinions. A thousand thanks again friends. |
Audio Fanatics, Bass lover
