32a distro build |
Post Reply | Page 123 11> |
adyk
Registered User Joined: 05 May 2009 Status: Offline Points: 442 |
Thanks(1)
Posted: 16 March 2012 at 8:29pm |
here is my distro build
Nick Sasquash
Young Croc Joined: 24 June 2006 Location: North West UK Status: Offline Points: 1408 |
very nice work
https://www.facebook.com/OperationSoundSystem/ |
kedwardsleisure
That's a neat little thing, better than those chinese efforts. What did you use to cut the square holes?
North Staffordshire |
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
very very nice work indeed.....
get some nocked togethor & sold ;)
one life - have fun!
Force fusion pro audio |
shagnasty
Nice job but why 4 inputs?
Not sure i would pass this on a PAT either due to the common neutral rail....
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
What are the 3 blue powercons for? The power in is via the 32a ceeform right? Nice job otherwise, Where did you get the volt display from?
100% Earth Moving Bass
jbinks
Registered User Joined: 27 August 2008 Location: Portsmouth Status: Offline Points: 1310 |
Lovely build, but as shagnasty said, why do you have 3 PowerCon inlets? and only one outlet? I'm only viewing on a phone so I can't make out the rest of the internal wiring too well but it looks like they are all paralleled?
If so that makes it rather dangerous!! (plug in a 16a plug -> PowerCon cable, connect to 16a supply, plug in a second cable and you have live pins!) Or am I seeing this all wrong? ps: how much would you charge to make something similar? (labour charge only) John |
GAZ.
Now I've sat and looked at the internal wiring, it seems the 3 blue powercons are being used as outputs? If that is the case, they should be grey ones like the one on the end.
Blue for power in, Grey for power out. |
ermita
Young Croc Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
Should be 3 whites powerCon (power out) powering the 3 matrix instead of 3 blue powercon? and guessing the single white should have been blue powerCon (power in).. Nice and tidy
Edited by ermita - 16 March 2012 at 10:30pm |
shagnasty
Yeah, I've just had a proper look, the words death and trap apply iaa...
Looks good, but no cigar.... |
ermita
what would be the ideal Neutral wiring.
GAZ.
Mains in is via the 32a ceeform so there should be no blue powercons on there, only white ones. |
