3-Way system |
wt-club
New Member Joined: 01 February 2020 Status: Offline Points: 9 |
Posted: 01 February 2020 at 6:07pm |
Hello everyone,
I have never posted on this forum so hope I asked this in the right place. English is also not my native language so my apologies if I make any mistakes. For the past weeks I have been planning a little 3-way soundsystem mainly for playing dub & reggae roots. I'm currently building 2 Eminence 15"scoops, loaded with 500W Beyma drivers and a crossover @ 150 Hz or 180 Hz. I was thinking about 1x15" bin for the mid-bass region but after searching the web I couldn't really find any good plans. As for the top, I'll create my own design since the inside doesn't really matter that much. All x-overs & amps are very easy and cheap for me to buy so that isn't really an issue. My question for you guys is if you have any recommendations for mid/top speakers, that works well with a scoop design. Would it be better to use a design with 2x12" speakers or just with one 15" driver. Thanks!
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
Many years ago I went to maybe three nightclubs (each around 500 capacity) that had the same basic speaker layout.
On each of the four corners of the dancefloor was a double 15" scoop (JBL 4520). Flown above the dancefloor at each end, was a 2 x 12" angled mid cabinet, together with an acoustic lens and a slot tweeter. I guess that this was an industry standard set up for clubs of that size, and certainly sounded good to me. |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Using scoops, I would suggest to run 'em not higher as 100-110 Hz to avoid somewhat the typical dip in response they have. Pretty much any 15" or double 12" can do 100-110 Hz and up with ease, so no need to have a crossover of 150-180 Hz, which already is more mid than mid-bass anyway and not something you want to feed scoops with, if you want to have it sound halfway decent
snowflake
if you are set on 3-way then use 12" and 1.4" compression driver. it is worth going at least four-way though. use a 6" and 1" compression driver above 12" or 15".
