3x Martin Atomic - how much power? |
Page <12 |
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7683 |
Posted: 10 September 2012 at 10:53pm |
As long as the supply is d-curve from source you will get away with murder, a d curve breaker makes a length of 6" nail look easy to trip!!!!
lost eden
Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
Posted: 10 September 2012 at 11:09pm |
I've tripped the 63A D-curve breaker on the distro in question before, without tripping any breakers further up the source, so that shouldn't be an issue - I'll check anyway. Turned out that 4x 1.8kW architectural wash lights (30A+ continuous) in addition to umpteen moving heads & 4x 1.5kW strobes was a bit much... This was the first time I realised that mains cables can actually get warm :)
shagnasty
Posted: 10 September 2012 at 11:13pm |
Yep, d-curve is good for strobes, big PAR rigs but in a an actual prolonged overload, it still trips like it should and stops you burning the building down, hence they work great for PA!
lost eden
Posted: 13 September 2012 at 4:34pm |
Success! Not a single tripped breaker all night, except when somebody put all of the blinder cells onto the same channel of the dimmers :/
Page <12 |
