  New Posts New Posts RSS Feed - 4/8 segment mode led Batton
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2013 at 4:58pm
What do you mean 'the file still can't be made properly'?
If you are defining a fixture profile/template, you should be able to define anything you want.
If the fixture is set up as:
1 = features
2 = feature adjust
3 = strobe
4 to 11 = Red
12 to 19 = Green
20 to 27 = Blue
why can you not simply create a profile that does that?
If the 27 channel mode uses RGBRGBRGBRGB, etc then just do that for the profile.
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2013 at 6:43pm
I was after a file that made it a lot simpler than having 27 dimmers on my screen, so i sent him the info..
this was the reply from chris at trace lighting
Realized last night that the way I was going to do it with the rrrrrrrr gggggggg bbbbbbbb mode wasn't going to leave you individual control of the cells. I take it none of it's modes are RGB RGB RGB ? That would help an awful lot an is very common. As it is you'll land up with 8 colour pickers or lots of faders, neither of which seem ideal.
one life - have fun!
Force fusion pro audio
