  New Posts New Posts RSS Feed - 4 eminence delta 12lf to play with but what to bui
bassdesigner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Topic: 4 eminence delta 12lf to play with but what to bui
    Posted: 19 September 2018 at 10:51am
sobi have four eminence delta 12 LFA drivers to build a project with? I'm thinking of building a set of twin 12" bass bins I know the parameters aren't the best out there but what do people think of a 150l tuned to 50hz? Any other recommendations welcome
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2018 at 12:35pm
4x cubo12?
2x tham12?
2x MTH30?
...I'm not sure of the TS of this driver but these seem to top 3 for 12" projects
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2018 at 12:58pm
I'd stick with reflex, 50hz is a sensible tuning but you could go a bit smaller volume.
It's not a strong driver for tapped horns...
"Battery Acid Sound System" blog hopefully happening in 2017
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2018 at 1:03pm
..just checked, Mr Cubo himself says the cubo12 is a good cab for this driver from 50hz upwards. So, you should be able to build a pair much smaller then your 150l idea and have a decent output from 50hz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2018 at 1:51pm
Quite shocked that these seem acceptable for such cab. Eminence are usually slated to death and are always deemed inadequate.
