4 turbo / funktion 118 vs 8 tham 12 b&c! |
Post Reply | Page 12> |
Angelow
Registered User Joined: 17 March 2010 Location: italy Status: Offline Points: 199 |
Posted: 07 July 2018 at 1:55pm |
Hello everyone, in sizing a system that can be versatile, from the big situation to the big parties I would like to know which of these bass solutions behave better in the frequencies ranging from 80 to 45 / 40hz
Use two 3-way horn loaded speakers per side, 80hz cut how low I would like to compare: from 2 to 4 bass type ts118 or f118 from 4 to 8 bass type tham 12 loaded with cone b & c 12ndl76 Obviously on the side of the stack. In my opinion, with the same size, even with less space, the tham12 sound much stronger and in this quantity flat up to 45-40hz what do you think?
MarjanM
12NDL76 is wrong 12 for the tham 12.
JonB67
Thanks(1)
Why not compare with the tham15?
Angelow
I saw the graph of 12ndl76 on the blog of martisson seems to me instead that it is linear, problem of cone desplacement?
Otherwise I could put one of the fah12fh, they are in Italy easily :) I was thinking of giving 500 / 800w a cone I could also compare with the tham 15, we make 6 tham box15 |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Without knowing what the tops are it's all a very open question.
MarjanM
Thanks(1)
12ndl76 is a midbass driver. It might simulate good, but the cone will rip apart very fast.
The 15NDL76 is tearing up the cone in some simple reflex boxes driven hard full range. LEt alone doing anything on sub duty. |
Angelow
which cone could I mount from b & c / faital / eighteen sound?
if I did 6 boxes per side of tham 15 "how would they sound compared to the turbo bass 18, funktion one f118? |
Angelow
the tops are the resolution3 ;)
Edited by Angelow - 07 July 2018 at 8:28pm |
Angelow
I just did a test with a tham 12 that built long ago, but i have never painted and finished :D
With the 12pr300 cone (removed from a satelite) just rising in volume you can hear strange pops :D is because it is a medium-low with very little excursion, or I did something wrong in the wood (poplar plywood)? |
MarjanM
Thanks(1)
12TBX100
Angelow
as an alternative in neodymium?
MarjanM
Thanks(1)
12NBX100
